Hi,
The latest VCDEasy 1.1.3 have a display window on chapter tab during chapter creation. My problem is, the movie was not shown on the window when I load them. I saw the timecode running but nothing are shown on the window. Then I tried TSCV to add menu and chapter. Everything went well until the menugen. The menugen just create a black box on the menu screen after I import a clip from the chapter that I have selected earlier. I don't know what has went wrong. It could be some workaround on this. Any help would be very much appreciated.
your probably missing 2 files. i believe they are mpeg decoder.ax and mpeg parser.ax. YOu need to get these files and then register them with reg drop.
Originally Posted by tempe
WOW!! sunmiztres.... haven't seen that name in a year or more since TSCV kinda died. How are you? I used to trade TSCV forum posts with you. Good to see you're still around. Later...
Sorry about the off topic guys...
By the way... TSCV ROCKS!!!! I wish that ttool hadn't quit working on it. I made some KILLER SVCD's with that piece of software!zeppsstteerr
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 04:48 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 20:00 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 08:17 -
TSCV on Vista
By mrcoolekin in forum Authoring (VCD/SVCD)Replies: 4Last Post: 11th Feb 2008, 23:04 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 15:13
