HELP!!! I just bought some VCD's and want to play them on my PC, but they wont play. Do i need some specific software? Someone please help - thanks.
Ok let me know if this helps open windows media player, where it says files scroll down to "all files" then you should see something like AVSEQ1.DAT open that and it should play, hope this helps!
oops forgot to mention in media player go to file open first then browse if d is your cd rom click that then do the all files .
Thanks for the help - I look around on the web and found that if you download XingPlayer for MPEG, this will play the VCD's.
Another question I have is weather this VCD will play on my Toshiba DVD player - any thought on this? Thanks again for your help.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE> -
If your VCDs are pressed discs, they will almost certainly play.
If your VCDs are CD-Rs, then it depends on whether or not your DVD player can read CD-R/W media.
Regards.
Michael Tam
w: Morsels of Evidence
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 10:55 -
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 18:57 -
Playing VCD on Computer or convert to DVD
By corumz in forum Authoring (VCD/SVCD)Replies: 3Last Post: 22nd Jun 2008, 06:35 -
Is there any free VCD playing software which meets my requirement?
By csh in forum Software PlayingReplies: 11Last Post: 20th Dec 2007, 02:21 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 13:25
