Hey i got a mac running mac osx and when i play this certain avi i have no sound what should i do. Ive played it with quicktime and Mplayer
Could be...
1. Don't have available audio codec.
2. Audio track available but not "enabled".
3. Volume is down.
4. Bug with OS/codec/QT interaction
5. There is no sound track.
6. Your speakers might not be turned on.
Possibilities:
*Take file to PC-test there, use Gspot to find what codec, use Google to DL codec if available.
*Convert while in PC to QT MooV.
*Test in OS9, see if works there.
*Get another copy from somewhere else or reencode.
HTH,
Scott -
Is this a DivX file with MP3 audio? Most DivX audio plays incorrectly (or not at all) in QT Player. Try VLC http://www.videolan.org.com
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 15:44 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
