Hi,
I have captured some footage using my Studio DC10+ card at it's max resolution of 720x540 however when i go to convert it to mpeg2 using TMPGenc it states that it is an invalid resolution - what can I do?? I really need to be a ble to convert this to dvd so I can burn it on my Pioneer A03 dvd burner.
Any help appreciated and I apologise if this is a 'dumb' question
Zed
maximal resolution is 768x576, just DISABLE STUPID "TV CROPPING". This function destroy interlaced picture, do not use it.
Open file in TMPEG and set resolution to 720x576, interlaced (there is no conversion 540 to 576 lines as before). Then load DVD template and encode. It MUST work, i tested it for long time -
On 2001-08-31 03:54:43, zed wrote:
Hi,
Zed
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE> -
Instead of using the pinnacle studio software to capture from your DC10+, try using avi_io or VirtualDub (info can be found on the tools section of vcdhelp.com). With avi_io and VirtualDub, you yourself can set the resolution to capture (720X576). 720X576 is an ideal source for converting to mpeg2 with cinemacraft encoder or tmpgenc (no rescaling has to be done).
Henk -
Thanks guys I will give that a go. where can I get the Cinemacraft encoder from? is it better than tmpgenc??
cheers
Zed -
Cinemacraft encoder is a commercial piece of software. You can find an evalution version (Lite edition) on http://www.cinemacraft.com or try http://dvdsoft.da.ru.
One big difference between cinemacraft and tmpgenc is the encoding speed. Cinemacraft is much faster. The produced quality of both encoders is good. Some people prefer the Cinemacraft encoder others prefer tmpgenc. When you want to use tmpgenc in combination with a video editing tool like Adobe premiere you should look at http://www.math.berkeley.edu/~benrg/avisynth-premiere.html.
Henk
capturing PAL signal as 1080i, 720p or just PAL ?
By adom in forum Capturing and VCRReplies: 3Last Post: 30th Aug 2011, 05:10 -
DVD is only available from Australia (PAL)- can I rip it and make a copy?
By stoker in forum MacReplies: 6Last Post: 22nd Sep 2010, 23:11 -
How to make DVD in PAL and NTSC?
By perik in forum Authoring (DVD)Replies: 9Last Post: 19th May 2010, 14:18 -
Miro DC10 /DC10+ and fedora
By bmw524 in forum LinuxReplies: 2Last Post: 14th Nov 2008, 14:54 -
Capturing PAL VHS and DVDs to NTSC DVD
By joelkranz in forum Capturing and VCRReplies: 1Last Post: 30th May 2007, 16:11
