I got dvd2dvd-r from a german site but i have problems installing it.
does anyone have a clue?![]()
when installing look out for the big button, i cant remember exactly but i think you have to put your mouse over it to hilight it.
you will see what i mean.
thingimijig. -
if you are using 98/me you need one installed, if using 2000/xp their should be one on the system.
download one for the correct system and install.
if you are using 2000/xp maybe you need one for your particular burner.
try the first option first.
we need one to access the dvdrom when reading compact digital audio.
thingimijig. -
Yessss,it's already running
Thnx for your reply's so far ,i,ll keep you informed
Problems Installing RipBot
By Dan_Joyner in forum Blu-ray RippingReplies: 8Last Post: 16th Apr 2013, 06:20 -
problems installing bd rebuilder
By davechubb in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jan 2012, 03:09 -
Installing Problems, No file created
By jburkhardt in forum ffmpegX general discussionReplies: 8Last Post: 1st Nov 2008, 22:56 -
Problems installing AIW drivers
By Ddanrr in forum Capturing and VCRReplies: 3Last Post: 10th Oct 2007, 20:14 -
problems installing flash player
By stretchweider in forum MacReplies: 3Last Post: 29th Aug 2007, 09:51
