Hi,
is there a way to get information about a DVD, e.g. if it is a single or a double layer DVD ?
Regards, Jens.
Assuming you are using a PC...in Explorer right click on the VIDEO_TS folder and select Properties. If it shows more than 4,700,000,000 bytes, then it's definitely dual-layer.
Ok, thanks. But is there also a way to find out when (min/sec) the DVD-Player changes over to the other layer ?
Regards, Jens. -
This is very simple, turn over your DVD if it is of Gold color then it is a dual layer.
If its Silver then it is a single layer DVD
Print DVD Information (VTS - PGC)
By dw-wizard in forum DVD RippingReplies: 0Last Post: 27th Sep 2010, 14:54 -
dvd information
By ht0160 in forum Authoring (DVD)Replies: 2Last Post: 11th May 2010, 14:40 -
Question about incorrect DVD information given by Gspot
By jimdagys in forum DVD RippingReplies: 2Last Post: 9th Dec 2009, 00:24 -
General information on how DVD players and their firmware (or software)
By Samazama in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2009, 16:51 -
Title Information Doubled-up using Linux DVD tools
By jblack in forum DVD RippingReplies: 0Last Post: 10th Apr 2009, 22:04
