Hello...I know I missing something...but I dont know what it is. I want toit will play on m take a SVCD and put the header trick on it and burn it in Nero to see if it will play on my dvd player. When I go open up TMPGEnc and go to mpeg tools and load the file I would like to rename I get a message saying that it cannot create the file. Am I missing a plugin of some sort? I downloaded the header trick and saved it to were the tmpgenc is installed on my computer...but still no luck. Anyone come across with this problem? Thanks.
I guess I worded that one wrong. I read about the header trick with no luck. I really dont know what the problem is...I get "cant create file". All the time. Has anyone seen anything like this?
are you trying to override a file that's in use? thats happened to me before.
Ok ...Im a jerk. Im tired and stupid....how stupid? The reason why I was getting that the file can not be created was because I didnt rename the file that was being created from the file i was muliplexing. thank you for everyone who tried to help...even if Im beyond help!!!
If you're trying to spoof a DVD player by wrapping a SVCD MPEG2 file in a VCD wrapper, then NER0 will do it all for you and you don't need TMPGEnc.
Just open NERO and select VCD.
Drag the MPEG2 file from the svcd into nero and it will be processed by NERO.
When prompted , "turn off compliance" and hit burn.
That's it !
It'll burn a MPEG2 VCD that'll work in quite a few DVD players.
It's a much simpler way of doing the "header" trick
I download a fair number of SVCD movies in BIN/CUE format. I load the BIN/CUE into FantomCD (a CD Emulator) . Browse the "virtual" CD and drag the MPEG2 file into Nero and burn. They look fantastic on my Toshiba DVD player. I'm watching LOTR Two towers (DVD screener) right now . Fabulous !
If this is what you're wnating to do, then great.
If not, then i've misunderstood your question. opps
CHeers
Star BuckA waste is a terrible thing to mind !
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 20:40 -
Could not perform end of Disc-at-once
By smt16 in forum DVD RippingReplies: 1Last Post: 18th Jun 2010, 06:50 -
Old computers can't perform! Can't play HD files.
By uehara in forum Newbie / General discussionsReplies: 10Last Post: 18th Feb 2010, 21:45 -
By mrjoetoff in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2008, 14:27 -
Error: Could not perform end of Disc-at-once - Please Help
By patrickj0781 in forum ComputerReplies: 7Last Post: 20th Jun 2007, 20:28
