I am trying to rip DVD to VCD first time using the Sefy Levy guide. When I try encoding using TMPEnc - Wizard, step 3, when I select Source Range, I get 0 frame and 0 running time. All the previous steps went successful - including SmartRipper and DVD2AVI.
I just skipped this and went to step 4 and under Bitrate setting, my movie info has 85 minutes and when I selected a CDR-80 min 700MB as my media type, I get a message saying I have exceeded disk capacity (obviously) but still I went ahead and started encoding - and I can see my movie frame by frame being encoded. What should I do not to exceed the disk capacity and why do I get a 0 frame in Source range.
Raghu
You can reduce the Audio to 128k, that will make it fit on 80min CDR.
As for why you couldn't use the source range, I have no idea, especialy
if you say the DVD2AVI worked well, sounds rather strange.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
DVD Ripping problem
By seajay in forum DVD RippingReplies: 23Last Post: 28th Dec 2012, 10:30 -
DVD Ripping, 4:3 and 16:9 Problem
By alimustafakhan in forum DVD RippingReplies: 2Last Post: 10th Jun 2010, 04:03 -
DVD Ripping Problem
By Sscheme in forum DVD RippingReplies: 3Last Post: 4th Jan 2009, 09:08 -
DVD ripping problem
By efiste2 in forum DVD RippingReplies: 5Last Post: 7th Sep 2007, 16:07 -
DVD ripping problem
By borisblavasky in forum DVD RippingReplies: 3Last Post: 17th May 2007, 11:38
