I still get that the server is down when i am looking for more information on how to burn my family video in xvcd and when i do a search with xvcd i got all the vcd.
I got no choice the SVCD doesn't work with my DVD panasonic SC HT290D player. The only good format that it will take is XVCD.
So i got a AIW7500 video card on my PIV and im trying to find a good guide on how to burn vhs video in NTSC XVCD with wich program and...
Thanks for helping me im sure that the subject is probably already done some where in this forum but i dont have enought anglish language to help me find it out.![]()
Results 1 to 14 of 14
There is a myriad of XVCD templates here. Check under "tools"Originally Posted by Kannif0
vcdeasy will burn xvcds with no problem. just turn off compliancy.
Really? I tried unchecking that box, but it would not let me create an XVCD with 704x480 rez... I was using 1.1.3, which one works for you?vcdeasy will burn xvcds with no problem. just turn off compliancy.
Thanks i find out some thing there im gone a try tonight and let you know.There is a myriad of XVCD templates here. Check under "tools"
http://www.vcdhelp.com/tmpgencxvcd.htm -
I really don't like VCDEasy 1.1.3. Did you select VCD 2.0 in VCDEasy. I use VCDEasy 1.1.2. :POriginally Posted by darkelf
Well i try with tmpgenc and this part is ok but when i get to the nero burning and i try to paste the file in The following problems were found.
-stream encoding which is invalid for a super video cd
-no video
-no audio
triyng xvcd ntsc from video vhs .
using nero burning 5 demo.
tmpgenc 2.5 30days try. -
you're trying to make an svcd. make a vcd. uncheck where it says make compliant or something like that.
Do you mean when i first start nero and it ask foryou're trying to make an svcd. make a vcd. uncheck where it says make compliant or something like that.
1- create standard compliante CD.
2- Use CD-i application.
i should just chek,
2- Use CD-i application? -
He means uncheck "Create standard compliant CD" in Nero when selecting the VCD mode. This will make a XVCD.Originally Posted by Kannif0
Hope That Helps!!! :P
thanks everybody, I figured out what I was doing wrong with VCDEasy...
Even if I unchecked "compliance" setting, I was getting errors trying to incorp a 704x480 or 720x480 file of either MPEG2 or MPEG1 (xsvcd/XVCD). My problem was that the original format was in NTSCFilm (23.xx fps).
I thought that frame rate should work, but for some reason it did not. Converting to NTSC native fixed my issues.
thanks again! -
Well i got my first xvcd working on my DVD but i got a very small screen like it take all the up side of the screen but no the larger of the 27 inches screen. I will try some other version of setup tonight.
I got a question. What is the best for me? I do my capture in avi format, And with tmpeg when i do my save is it better in mpeg2 or mpeg1 or doesn't it matter beacause i save a vhs copie. -
From what I've concluded, the MPEG2 algorithm is better than MPEG1 at any given bitrate. The comparison is akin somewhat to the MP3/MP2 audio comparison. A 224k MP2 file will sound identical (to a mere mortal set of ears) to a 160-192k MP3 file. This is assuming a CD-quality (or better) source WAV file.
MPEG2 for video is supposed to be more efficient and handle fast transitions better than MPEG1. The VBR settings are supposed to be better at a given bitrate also. I've heard that XVCD/MPEG1 compatability is better for the most part with DVD players when compared to XSVCD/MPEG2. Not really a problem unless you have a picky player.
A *VERY* important part of the puzzle is the quality of the input signal. Generally VHS caps are not 'clean' as you would expect a DVD rip to be. The additional noise could skew your results in both directions, depending on your specific settings.
When in doubt I have found that MPEG2, (especially with 2 pass VBR) under TMPGEnc gives slightly better results for my eyes, with my DVD player (Daewoo 5800).
With all of the templates that everybody is creating for both XVCD and XSVCD'z many of my points could be rendered moot due to extreme tweaking.
Try a few 30sec clips using different settings, try them out on your final viewing setup (whether it's a DVD-ROM or a settop DVD player). You may find that MPEG1 gives you better quality for a given source file.
On the whole tho, if you can run with MPEG2, it is the better of the pair.
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 18:55 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
