Results 1 to 10 of 10
  1. How can I merge m2v with m2v ?
    Is it possible ?
  2. yes it is possible. there are a few programs that will do this but alot of people run in audio out of sync. i believe tmpgenc will do it. i do this sometimes by renaming the vobs of 2 movies so that they in order and then demux with vobedit to get the 1 audio track and 1 m2v track. this works well and the audio seems to be in sync.
  3. if you are authoring with maestro just stick the 2 back to back in the same timeline and it works fine. i have done this a bunch of times.
    True Story
  4. What if I'm going to authoring with IfoEdit?
  5. Originally Posted by komanch
    won't work in ifoedit i believe. sorry
  6. I just did this the other night with tmpgenc.
    Worked perfectly.. I put all 3 svcds of catch me on a single dvd.
    Just used the merge function in tmpgenc.
    Btw, I suggest you merge them as mux'd mpegs, then de-mux them
    and stick them in maestro or the authoring program of choice. Keeps the
    audio in sync.
    -d
  7. Originally Posted by dc91gt
    Worked perfectly..
    What Type Mpeg I should set,
    MPEG2 Super VideoCD (VBR)?
  8. Originally Posted by komanch
    Worked perfectly..
    assuming you are going to DVD-R as the final destination. Then you want mpeg-2 program -- not super videoCD.
    -d
  9. dc91gt; could you point to such a program?
    I just got my DVD burner and are battling with learning how to use it.
    TMPGenc causing most of the problems.
