My burner is two years old, and I am a heavy user. I was just wondering in your opinion how long should a cd burner last, or is known to last.
i have plextor scsi cd-r 's that are many years old and burned 1000's of cd's and still work fine .. i believe the quality of burns on the various 4x and 8x plextors scsi's were and still are the best avaible for audio cd's, vcd's and svcd but i might be smoking crack and its all in my head..
i think it would depend on the brand and such a lot for max life .. -
come to think of it -- i have had one 4x burner die but taking it all apart and cleaning it made it work it again ... not even sure where that one is now ...
well checked and last time I heard from the person I gave my 5 year old 2x burner, its still working.
I had a ricoh that started burning some coasters after about 2 years, but it was a 4x flashed up to 6x so it may have had other issues... I never tried cleaning it or regreasing the rails because by that time I wanted a 16x (and now even 48x are around $50 so unless you're strapped for cash it'll probably last until you want to get a new one).
I gave away a 2x a 4x and a 8x drive, all still work afaik. However, my 24x AOpen died after 2500 CDRs approx. Got it exchanged under warranty. Depends a lot on what writer you buy and how much discs you burn with it...
My old 8x SCSI ( with a 4 MB buffer no less! ) lasted about 1000 CD's. It got erratic towards the end, and wouldn't give me an error, it simple fizzled. It still reads, but can't write. My new 52x24x52 was $49 bucks, so I'm not real interested in teh extended warranty, in 2 more years I'll be buying a 60x48x60x(8x DVD?rw) for $100!
To Be, Or, Not To Be, That, Is The Gazorgan Plan
How long is your hair?
By johns0 in forum PollsReplies: 28Last Post: 28th Nov 2010, 03:20 -
How long should a DVD burner last?
By Regor21 in forum DVD & Blu-ray WritersReplies: 12Last Post: 4th Sep 2010, 14:31 -
how long
By Tobias0815 in forum FeedbackReplies: 3Last Post: 1st Jul 2008, 20:08 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15 -
alltoavi how long does it take
By pw29010 in forum Video ConversionReplies: 1Last Post: 8th Oct 2007, 16:38
