I recently bought a Pioneer A05 DVD burner (gets here tomorrow). I have many home movies that were encoded in mpeg2 using my Dazzle Digital Video Creator 150 that I saved as SVCDS. I no longer have the data on my harddrive but would like to take the SVCDS that I have (4 to start) and make them into 1 DVD. How would I go about doing this? I would prefer them to be all one mpeg2 stream if I can do that, or mutiple mpeg2 files that play continuous, one right after the other. Thank you for your time.
	First you'll need to put the mpg's from the SVCD's back on your HD. Then join them into one file with DV Tool. Demux into elementary streams with Tmpeg. If the video is 480x480 you'll have to patch the headers with DVD Patcher. You'll need to resample the audio from 44100 to 48000.
  Merging/Converting Multiple M2TS files to MKV With Multiple Audio TracksBy Nicholas S. Folsom in forum Video ConversionReplies: 1Last Post: 13th May 2011, 19:34
  Multiple AVI files to multiple DVD discs, no quality loss, chapter per aviBy Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 09:27
  Invalid DVD / Multiple errors with multiple programs...By multiplex in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2009, 16:50
  Play multiple streams in DVD (Merge multiple streams)By sebastien91 in forum SubtitleReplies: 0Last Post: 25th Apr 2009, 19:44
  Authoring Multiple Language DVD with multiple language menu optionsBy kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 17:29
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
