You know, like a tv episode as a standard VCD with 3 of four copies at different bitrates. I would have a menu that looked like this.
1. show @1150 kbs
2. show @1500 kbs
3. show @1800 kbs
etc, etc, etc......
Kind of testing my DVD player at different bitrates.
Sure you can do it but technically it won't comply with the VCD standards. The first track, at 1150k, should play regardless but there is no guarantee with the other ones.
If they are all the same MPEG spec. All MPEG-1 for example. I am even just dumped multiple mpegs onto a data cd and I can play it in my apex dvd player. Comes up with folders for mpegs and i can play them albeit with no playback control.
Originally Posted by adam
Originally Posted by telemike -
Long, long ago, while doing MANY, multiple-file CD-RW test encodes, I found that certain sequences of files would cause errors. Each file would play if first on the disk but some sequences of files would not play correctly. I spent quite some time confirming this as I thought I was going crazy when an encode method I had noted as giving good results failed in a second or third comparison test. I was trying lots of variations but mainly bitrate, GOP, resolution, interlacing, etc., all Mpeg-2 and mostly CVD or above.
These were not burned as VCD, just mpg files on data disk. The same files that played fine 1 -2 -3 would fail if reversed to 3 -2 -1, or 2 - 3 - 1, but the FIRST file would always play OK.
I am sorry I do not remember exactly what caused the issue, as I recall it was using a hi-bitrate 720x480 triggered it but I really can't say for sure.
So if you are doing a lot of short comparison test files, or mixing file types, if one doesn't work try playing in different order. -
My own DVD player was fine with all sorts of nonstandard files in any order (written as a v2.0 VCD), only thing was, you had to make sure they were at least a certain size (i dunno, maybe the equivalent of 10 secs of normal VCD). So, very short, very low bitrate files did odd things, like starting halfway through and having bad picture. Those, and tracks with too high a bitrate, tended to make it crash as well. So go throw a load of 5-minute clips of the same thing at different test rates onto the same VCD, you'll get the results you're after but a few "hard" resets may be in order!
-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more! -
The answer is "yes", you can put multiple different "X" clips on one disc.
Indeed, the Official VCDHelp.com PAL/NTSC Demo Video-CD has a number of XVCD clips for testing this very thing.
Regards.Michael Tam
w: Morsels of Evidence
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
VHS tape won't rewind in mulitple players
By robjv1 in forum RestorationReplies: 15Last Post: 19th Aug 2009, 17:18 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Most compatible codec, Lossless bitrate, and max bitrate
By sevenlayercookie in forum Video ConversionReplies: 2Last Post: 6th May 2009, 20:43 -
Editing to match tapes from mulitple cameras of the same event
By SCDVD in forum EditingReplies: 5Last Post: 17th Mar 2008, 18:06
