I'm trying to back up a DVD-9 with four 45min PCG. I want to create a new set of VOBs with only two PGC (to fit on a DVDR). Here's what I'm planing to do:
1) Rip DVD
2) Use IFO edit to create new IFO/VOBs for each PGC
3) Demux new files to m2v/ac3
4) Load two m2v/ac3 at a time in maestro, re-complie
5) Burn
This way I'll get two titles (to easily switch between each PGC without making a menu) and the chapters remain intact.
The problem is I can't figure out how to demux the IFO edited files into one m2v/ac3 stream. I have to either demux each VOB and generate 2-4 m2v files, or burn the files to a DVD-RW and then use DVD decryter to demux w/ streams enabled.
I know there has to be an easier way then this![]()
Q: How can I take a DVD with four PGC of 45min each, and create a new DVD with only two 45min PGC (or two movies/titles).
Thanks in advance
Best Demux Software ?
By webstar in forum MacReplies: 15Last Post: 25th Apr 2013, 01:18 -
why does ripbot sometimes demux twice ?
By zero7404 in forum Blu-ray RippingReplies: 0Last Post: 20th Jan 2012, 23:12 -
Convert non-compliant VOBs to "good VOBs"
By pmolson in forum Video ConversionReplies: 3Last Post: 24th Oct 2008, 11:52 -
Demux WMA10
By rjc7394 in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2008, 23:51 -
How to demux
By php111 in forum Newbie / General discussionsReplies: 16Last Post: 2nd Aug 2007, 19:07
