Im trying to extract the audio in virtual dub, to PCM wav, the file information is below-
but when i try and do this in full processing mode, i get this error-
any ideas?[/img]
OK I've had this prob myself and have messed with LOTS of ways to sort it and this is the quickest...... Load your xvid into TMPG, then go to file - output to file - WAVE file will save the wave out which u can put into virtual dub and it works
You can't decompress the audio if you don't have the codec installed. Vdub is telling you you don't have the audio codec.You can extract the audio, copy it exactly, but that won't help you.
48000Hz smells of AC3, install the AC3 codec?To Be, Or, Not To Be, That, Is The Gazorgan Plan -
i have the codec installed, because when i play it in WMP i can hear the audio :/
First open your avi in Virtualdub. Go to the audio tab and select direct stream copy. Then select save wav in the file menu. After that rename the wav extension to ac3 and convert with headac3he.
Get headac3he at www.doom9.org
Extract audio from MP4
By aiyoyo in forum Video ConversionReplies: 5Last Post: 12th Dec 2013, 15:35 -
cannot see or extract audio from AVI
By Srivas in forum Video ConversionReplies: 6Last Post: 7th Dec 2011, 23:47 -
extract a matrice from an xvid avi file ? [SOLVED]
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 15th Nov 2011, 09:14 -
HOW do I extract 1 audio track from a .ts / .m2ts with 4 audio tracks?!
By elgy in forum DVB / IPTVReplies: 25Last Post: 23rd Jan 2011, 23:28 -
Extract Audio from XviD MPEG-4 video
By MI6 in forum AudioReplies: 2Last Post: 3rd Jan 2009, 05:58
