Strange, I got this flick.avi which plays perfectly synched in WMP. I follow the all in one avi to mpg conversion guide
http://www.vcdhelp.com/divxtovcd.htm
and when I go and test the resulting mpg the audio is totally out of synch.
Any ideas![]()
WMP is very good at keeping avis in sync so never use it as a judge of results you can expect after encoding. Did u load the uncompressed wave back into virtual dub and play it to check syncing before sending it to TMPG? It may well have been out of sync before conversion to mpg
thanx for the fast reply. Could you please explain to me how I should go about doing this (reloading the wav back???)
Youve opened the avi with virtualdub, saved the sound as uncompressed wave. Now in virtualdub go to audio - wav audio... and open the wave. Now play parts of the movie to check syncing. If its out then welcome to the joys of resyncing sound. you can adjust the audio positioning by going to audio - inerleaving and putting in a figure in ms to resync the sound IF its a constant sync error for whole movie
If you are using TMPGenc you can delay or increase the position of the audio positioning relative to the Video under the source tab. I have used this to good effect in the past but I am afraid it tends to be trial and error!.
I have been advised in other posts that you could always use TMPGenc to demultiplex and then remux using BBmpg which is supposed to put the synch back in the movie. If the out of synch is constant this method should work, if its variable then you may need to experiment with the suggestion above.
Always make sure you save out the wave, then use this as your audio source and the original Avi can be used as the video source.
Hope this helps, Good Luck
Tom
Prefer using virtualdub myself, u can put in the delay and press play, and watch the effect of the delay before processing or saving to file (not so much hit and miss)
export subtitles created/synched in Authoring Works
By ecc in forum SubtitleReplies: 1Last Post: 21st Feb 2009, 19:44 -
AVI Conversion - Audio out of sync
By pinovecs in forum Video ConversionReplies: 3Last Post: 17th Oct 2008, 17:11 -
Audio and video not synched when authoring HD-Mpeg2 to DVD using Moviemaker
By edong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 24th Sep 2007, 18:44 -
WMV video and audio slightly out of sync on conversion to AVI
By Calidore in forum Video ConversionReplies: 8Last Post: 10th Jul 2007, 09:48 -
riverpast rm to avi conversion sound out of sync
By princevegetam in forum Video ConversionReplies: 9Last Post: 2nd Jul 2007, 03:45
