I want to put a five-minute showreel on CD-ROM (Not DVD - I haven't got a burner). The main emphasis is to enable the recipient to view the video on a computer, without doing anything too techie, and I am more concerned with the ease of use than the absolute quality. Ideally I want someone to be able to shove the CD into any old computer and watch the movie.
I am equipped with Edition/Purple (which can output DIF, AVI, MPEG2 and WMV amongst others) and TMPGEncoder (so I can convert files to MPEG1)
The problem I am having is that the original video is 16:9, but I can only seem to retain the correct aspect ratio when I output as AVI (and the data rate is too high at a decent resolution.) or using Elecard.
I want the end-result to be easily played using Windows Media Player, but MPG files only seem to play with the correct aspect ratio using Elecard.
What am I doing wrong?
What (of the umpteen options open to me) should I choose?
Can I burn one CD with an AVI, an MPEG1 and an MPEG2 file and let the user try each one out?
media player is bad for that .....
have you though about using quicktime instead ? 1. it plays on just about everything 2. a lot people viewing showreels accually use macs (not that there would be problem playing the QT on a winPC)
you would get max quality in the smallest space (on a unversally accepted format that is) really and still preserve formating ..
on the other problem of aspect ratio -- if you made your film at 720 x 380 (or so) or ~360 x 190 - it should play in the correct aspect ratio
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 08:33 -
putting it together
By rickb2010 in forum Newbie / General discussionsReplies: 1Last Post: 28th Jan 2010, 14:40 -
Help putting together a DVD
By Keano16 in forum Newbie / General discussionsReplies: 5Last Post: 30th Oct 2008, 12:56 -
Best Settings - How to compress 5 min Showreel
By markwhite1980 in forum Newbie / General discussionsReplies: 5Last Post: 11th Nov 2007, 22:00 -
Best settings/format for short showreel
By markwhite1980 in forum Video ConversionReplies: 4Last Post: 11th Nov 2007, 21:58
