Anybody have an idea how to recompress in Virtualdub from xvid to divx?
I know I will lose a little quality but willing to do that for less headache on encoding.
I have frameserved previous xvid from virtualdub to TMPGEnc but they tend to get a weird 'go a little out of sync then back in sync' tpye thing and it's a little annoying![]()
Thanks in advance for any help.
dont understand why u having probs with xvid? have u saved out sound as uncompressed wave, aand loaded the wave into virtualdub before serving, works OK for me. Anyway in virtual dub go to video, set full processing mode and go to compression, select the compression mode (divx,etc) and configure the quality settings. then save your avi with new filename. But it takes AGES and sorting out the quality configs may take u some time to get the quality u want......
thanks Narked.
I appreciate the info and after reading a little more I will try uninstalling Nimo and reinstalling etc to try and egt correct as I used to make great mpg's w/xvid and not sure what I messed up and downloaded that changed that
always learning always learning -
I've read somewhere that nimo codec pack build 8 is unstable? perhaps only use build 7 instead?
N
you know it's the anti-Midas touch when all you touch turns to shit........
mux xvid without recompressing anything?
By redrocklobster in forum ffmpegX general discussionReplies: 5Last Post: 12th Jun 2010, 10:35 -
AVI/Xvid->MP4/Xvid w/o recompressing?
By chconnor in forum Video ConversionReplies: 15Last Post: 9th Feb 2010, 16:47 -
How to reduce bitrate of Xvid without recompressing or faster than this?
By dzsoul in forum Video ConversionReplies: 2Last Post: 18th Jan 2010, 05:59 -
Re-encoding XviD (For DivX Player)
By ZiGGY909 in forum Video ConversionReplies: 11Last Post: 16th Dec 2008, 19:07 -
Help with re-encoding avi files (XviD/DivX)
By noskid21 in forum Newbie / General discussionsReplies: 2Last Post: 18th Aug 2007, 14:24
