  1. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    When I'm creating a dvd mpeg (TMPGEnc), what maximum file size should I create?
    Is there a file size these dvd-r's won't accept?
    For instance, can I burn a 4.25gb file?
    Thanks,
    Will
    Aug 2002
    I have burned a 4.3 GB mpg file after encoding it to DVD and then burning... Be careful though it depends on what software you are using. Some software will not even handle the file or will crash. I could not play the 4.3 GB mpg file in WinDVD for example or PowerVCR both would crash.. But the DVD software handled it, converted it to DVD and burned it.
  3. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    Please visit this site for THE SIZE of the DVD-R
    not 4.7 like the pckg says , but 4.37 gig (4.70 BB) of data, over 2 hours of video
    http://www.dvddemystified.com/dvdfaq.html#3.3
