I've just got hold of Harry Potter 2 on divx format. I'm not new to dvd-r/vcd copying etc but am new to Divx. I'm trying to get the 2 cd-r's converted to go onto dvd-r. I've succesfully converted the pics to .m2v & got the sound off in .wav format then re-encoded to .ac3. Problem is I've not been able to do any of it in one go without splitting sound/video - Using TMPGenc, every setting I try comes out silent. Am I missing a codec perhaps-I've installed latest divx ones. When I use Spruce Up to put them back together the sound is running out of sync. I've got an excellent pic & sound but out of sync. Do I have to set the wav file to the length of video manually then re-encode to ac3? When using virtualdub to extract the sound I got a message saying something about odd encoding (cant remember exactly) I think it said there would be skew?? Whats that all about & is that whats caused the problem?
If you get such a message when opening a video in VDub, always extract the complete audio stream to an uncompressed WAV/PCM file first (set No Compression under Audio/Compression and stereo,16bit,high quality under Audio/Conversion). That should remove any inserted skew.
There are only 10 types of people in the world:
Those who understand binary
and those who don't. -
Thanks for that. I dont remember changing any settings when I extracted it. When I listened to the playback afterwards it sounded ok- so I assumed it to be alright. I never thought about sync untill it happened. I'll retry it making sure the settings are as you suggested.
Sound out of Sync in conversion
By opala in forum Video ConversionReplies: 2Last Post: 17th Apr 2009, 19:15 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 21:18 -
mpg video conversion out of sync
By pettinej in forum Video ConversionReplies: 2Last Post: 14th Oct 2008, 20:49 -
Conversion to MPG puts video out of sync
By ral315 in forum Video ConversionReplies: 5Last Post: 5th Aug 2007, 19:18 -
riverpast rm to avi conversion sound out of sync
By princevegetam in forum Video ConversionReplies: 9Last Post: 2nd Jul 2007, 02:45
