Hi,
What TV tunner cards are compatible with Radeon 7500?
What is your experience in mixing Radeon 7500 with tunner cards?
I was thinking of buying WinTV-FM or Aver Studio.
Regards
Jose
I have an ATI Radeon 7500 with an ATI TV Wonder VE capture card.
The capture card works fine on my system but this is obviously highly dependent upon the system within which it operates.
The only problems that I have encountered with this card have been with installation of the drivers and with upgrading the Multimedia Centre (MMC) software.
The reason why I chose the TV Wonder VE as opposed to the plethora of other cards was to promote maximum compatibility with my ATI graphics card. I think it works well but the maximum capture resolution is somewhat limited which requires that I re-size during encoding.
Nevertheless, it produces good quality AVI captures and has a good tuner. It is worth the minimal cost (approx. $45).
Hope that helps from the ATI hardware perspective. -
I have a Radeon 7000 64 mb ddr and a aver tv stereo. I am using the btwincap drivers and use virtualdub_sync to capture vfw codecs and iuvcr to capture directshow codecs. Mostly I am using the tuner to capture cable tv to main concepts dv codec, trimming out the commercials and encoding with main concepts mpeg encoder to dvdr specs. Very happy with speed and output. I use either my trusty old hollywood plus or powerdvd xp out of the Radeon's S out to display the output on my TV. I can encode the captured footage at less than real time with a P4 2.4B overclocked to 2.88. Quality is superb and no compatibility problems. I didn't bother to install avermedia's drivers as I knew I wanted the btwincap drivers. Good Luck!
Compatible problem – SD vs. SDHC card
By coody in forum MediaReplies: 19Last Post: 26th Jul 2013, 11:15 -
Happauge WinTV-PVR 500/1600 Streaming Dual tunner
By valis77 in forum Capturing and VCRReplies: 0Last Post: 1st Mar 2011, 23:41 -
For video card, should I get two Radeon 57xx or one 5850?
By jeanpave in forum ComputerReplies: 12Last Post: 24th Aug 2010, 02:17 -
select a video capture card that compatible with FMLE & linux
By iut_662 in forum Capturing and VCRReplies: 0Last Post: 10th Sep 2009, 04:05 -
H264 x264 ATI Radeon Vid Card Question
By mforcex in forum Newbie / General discussionsReplies: 6Last Post: 25th Jun 2007, 10:59
