I'm really a newby with DVD ripping and copying so can anyone tell me please which guide i should use.....if it's available
I now use the cretin's guide
Thnx ... Jesprulin![]()
because i know you have just got cce i would recommend getting the programs dvd2dvdr 1.3.2. and ifoedit95.
dvd2dvdr does everything automatically aslong as you hace cce and ifoedit installed. when its finished it will leave you with a .m2v file and an .ac3 file then all you have to do is author them back to vobs.
thingimijig. -
Thank's again for your help,as soon as i have time(probably this weekend) i'll get started with it.
Do you have any clue how much time it will take me to copy a dvd with this software?
With rempeg2 it took me between 6 - 8 hours (depending the lenght of the movie)
Jesprulin -
i usually stick the disk in just as i go to bed so it cant be more than 6-7 hours.
when i wake up dvd2dvdr has ripped it, got the dvd2avi file, then the avisynth script, then re-encoded it all automatically.
all i have to do is author the m2v and ac3 files then burn.
thingimijig. -
whats the bug?
is it to do with the authoring?
is it just on ntsc?
thingimijig. -
See all the details here -whats the bug?
http://www.vcdhelp.com/forum/viewtopic.php?t=124578&postdays=0&postorder=asc&highlight...0cce&start=520
Please guide to BRRip
By RoTeMaN in forum Blu-ray RippingReplies: 2Last Post: 19th Aug 2010, 00:28 -
Numpty's Guide Please
By Dan Dare in forum Media Center PC / MediaCentersReplies: 7Last Post: 10th Dec 2008, 01:55 -
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 10:34 -
HC Guide?
By Rauli in forum Authoring (DVD)Replies: 6Last Post: 10th Aug 2007, 22:34 -
How to use Linux? Guide
By mjack425 in forum ComputerReplies: 2Last Post: 24th May 2007, 22:55
