i have veritas software and a program called recordnowdx can i use this to make vcds and if so how?
the best there is
I think you need to do a lot of reading my friend, you can use Recordnow DX to burn compliant VCD's which is the end process, go to the guides section on the left to learn how to convert DVD to vcd, personally I use smartipper, dvd2avi, tmpgenc and then record nowdx to burn.
I dunno...it might work -
chewy thanks for replying im trying to learn but you have to understand that all this is like reading another language what software do i need to convert dvds to vcds
the best there is -
See this section for ideas:
http://www.vcdhelp.com/dvdrippingPanasonic DMR-ES45VS, keep those discs a burnin' -
http://www.vcdhelp.com/forum/userguides/135238.phpOriginally Posted by hoehand
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
