  1. Hi
    I have an Xvid that I need to convert to VCD, but the audio is in AC3 format. I've extracted it using VirtualDub (which won't convert it), and I now have the AC3 file sitting on my desktop. BeSweet doesn't seem to recognise it.
    Is there a quick and easy way to convert this AC3 audio to WAV?
    CobraDMX
  2. I followed the guide and HeadAC3he said it "Could not find the data chunk", and will not load the sound.
    Any ideas?
    CobraDMX
  3. Don't worry - I got BeSweet to work for me. Now all I have to do is sort out the slight audio sync problem that's on the first file!
    CobraDMX
  4. Hi
    I've had the same problems with headAce 3 and other probs the best tool I've found for this problem is goldwave
    When u have opened up goldwave go into open import the movie. This then will deflash this to disk, go to file and save as this will then convert the file into a wav file. Make sure u have enough space on your hard drive some times it can take up to 1 gb.
    Hope this helps kb
  5. Banned
    Jun 2001
    UK
    Originally Posted by CobraDMX
    Hi
    Vdub might do
    http://www.moonlight.co.il/download.htm
    Moonlight Odio Dekoda DirectShow® filter, binary (71,855 bytes, ZIP)
    HTTP Download, U.S. Primary (it is recasting)
    HTTP Download, U.S. Secondary <<<<<<<<
    HTTP Download, Russia
    Now work with AC3 just like anything else
