hi all...im new...this is my first project and using tmpgenc to convert, but I can't open any of the avi files and receive the "...file not supported" message. I read the problems part and it say I need to install the divx codecs, but my question is do I need to install all three versions? Or just the latest 502 somthing? Also, is this the best way with best quality result?
The codec you need to install, depends on the codec that was used to encode your file. If you install Divx5, this wont decode a divx3 or xvid file. So yes install all of the divx codecs and possibly xvid as well. TMPGEnc is a very good mpeg encoder.
test these out, see what you have missingOriginally Posted by vitamine
http://www.vcdhelp.com/forum/userguides/135217.php
How to convert the 1gb VOB file to 80Mb AVI file ?
By zohaibshaikh in forum Newbie / General discussionsReplies: 3Last Post: 17th Oct 2010, 07:41 -
Best way to convert a .dv file to an .avi file is...... Survey says ???
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 6Last Post: 3rd Feb 2010, 23:39 -
I want to demux an .mp4 file and convert to a microsoft dv .avi file
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 13th Sep 2009, 22:42 -
how can I convert dvd file on my computer to avi or a different file
By brew in forum Video ConversionReplies: 3Last Post: 19th Nov 2007, 20:21 -
AVC FILE to AVI/MP3 File: How to Convert?
By devilcoelhodog in forum Video ConversionReplies: 3Last Post: 25th Jul 2007, 22:49
