Hello,
Can I take the straight Mpeg1 clips captured from WinTv2000, and burn them to VCD without converting the files to something else first? The reason I ask is that I have gotten “great” quality capturing from WinTv2000 compared to the raw AVI clips from VirtualDub. Also, can these Mpeg clips be edited/saved/burned? Or do I have to convert the files after they have been edited.
Thank you in advance.
Paul
If the WinTv2000 MPEG-1 files meet the VCD specification of:
NTSC
1150 kbit/sec
352 x 240 pixels
29,97 frames/second
23,976 frames/second NTSC Film
Audio:
224 kbit/sec MPEG-1 Layer2
PAL
1150 kbit/sec MPEG-1
352 x 288 pixels
25 frames/second
Audio:
then yes. -
Maybe I should have put explained in a little more detail. If the WinTv2000 MPEG-1 meets the VCD specification I outlined, then yes the file can be burned strait to VCD format on CD without any additional encoding. You can save the files to your hard drive in the normal way. You can edit them with any program that can edit MPEG-1 files. They do have to be burned by software that has some sort of VCD setting, such as VCDEasy or Nero.
Hwoodwar,
Thank you.
Apparently the WinTv2000 capture does not meet the above standards because Nero didn’t accept the .mpg file. I found a link on this site for capturing with the WinTv PVR card, and followed the instructions exactly.
I captured the test clip, downloaded/installed TMPGEnc 2.5, and did the Simple Multiplex operation on the test clip as described in the instructions. That went ok. I pulled the file back into Nero, and successfully burned the test clip .mpg file to a VCD. Unfortunately I was unable to get my DVD player to recognize the disk. I tried a few more times with different disks, but the player will not see the VDC.
I know the player sees VCDs, because I have burned slide shows to VCD via ProShow Gold.
Could you or anyone suggest what I might be doing incorrectly? Thanks in advance,
Paul -
It's way too late for me! I have Nero 5.5.9.0 after all, and I have followed all of the instructions under the How To capture and burn a VCD with the WinTv2000 capture software.
Any and all help would be appreciated. Thank you and good night. -
I got the player to see and play the disk after I put a menu on the disk first. Thanks.
Captured Video Clips
By Prepper in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2012, 13:02 -
Default naming of captured clips in Vegas Movie Studio 10
By Medwynd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 10th May 2011, 17:18 -
cannot burn or copy captured mpeg2 files
By DirtBikeMike in forum Capturing and VCRReplies: 12Last Post: 3rd May 2011, 07:49 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 16th Dec 2008, 23:38 -
Windows Movie Maker - Why is there no sound after video clips captured?
By coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 6th Dec 2008, 09:45
