fitting a movie to one cd using TMPGENC after I follow the direction on the
newbies guide. When I try to encode the movie everything went fine but when the movie is half done it give me an error saying ( ILLEGAL FLOATING DECIMAL POINT CALCULATION ORDER. ) What does that mean I can't figure it out. Or maybe the Setting r wrong in TMPGENC.
You need to set the minimum bitrate higher than "0," when using two pass encoding.
Hay! mrtristan thanks for the information I change the birate and it work fine. Again thanks
So THATS how to remove that error!
I can finally convert all my Quicktime music videos, then... I hope
-= She sez there's ants in the carpet, dirty little monsters! =-
Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more!
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
Converting 2-Disk Sets to 1 Disk
By 1337assassin in forum Newbie / General discussionsReplies: 18Last Post: 23rd Oct 2010, 09:53 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 12:15 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 22:27
