  1. is there someway to cut the bottom of the screen off, perhaps by reencoding with Tmpgenc? I used settings for SVCD, any ideas why the green bar is there? I was capturing VHS via composite. TIA
    Oct 2002
    Manila, Philippines
    just cut it in TMPGenc, MPEG setting, Clip Frame
  3. This is the overscan area. This is usually cut off on a TV by the borders arount the CRT but some or most capturing devices/programs will capture it; some may also allow you to crop the image.
    I know FlaskMpeg encoder will allow you to crop Vob files so I would think that there would be an app to do this with a plain mpeg.
    Nov 2002
    Texas
    Yeah, sounds like overscan. You may be capturing at higher resolution than your card can support, so try something lower. A decent card shouldn't have this problem at 640x480 or maybe 704x480. 720x576 is probably a stretch for a lot of cards.
