I have just recently downloaded an AVI File and I want to convert it to a mpeg so i can do a vcd.
But when I come to cut the movie to make it a suitable size, the dubbing is out by 10 seconds on the second half of the project ( the first part is perfect).
As per the help guide I did the following by. Making a wav file off the avi file, but i then come up with this error VBR audio stream detected, which is noted in the how to pages. So I have downloaded Virtualdub mp3 Freeze as directed and followed the instructions, Finding no freezes, and therefore I then made the wav file. I then use TMPGEnc as per instructions to cut the movie, but i keep having the same problem.
Can anybody help because im running out of hair to pull out.![]()
After you made the WAV, did you make sure you re-save the WAV as an
Uncompressed WAV file ? I usually do that with WinAMP.
When using an Uncompressed WAV file, you have less chances of having an
Audio sync error when encoding the AVI/WAV into MPG.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14 -
fix audio sync in dual audio avi
By jin007 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2008, 11:07 -
VCD audio out of sync on player
By burnerbie in forum Authoring (VCD/SVCD)Replies: 2Last Post: 10th Aug 2007, 13:15 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22
