if i have a movie files in "dat" format , and i want cut out only last 15 minute is that any software can accomplish this job another than using vcdcutter , any suggestion.
commercial product and non commercial product also can
i have tried to edit dat. files but the sound was dramatically off on the finished product. only way i know of is to use vcdgear located in the tools section and convert it to mpg then cut off what you don't want. i'm unsure however if the same program can convert it back to a dat. file
h.264 ts cutter
By stewart041170 in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jan 2010, 15:06 -
Looking for software to use as an AVCHD frame cutter
By sebaz in forum EditingReplies: 2Last Post: 19th Sep 2009, 14:29 -
MKV Cutter ??
By RVD2720 in forum Video ConversionReplies: 2Last Post: 13th Mar 2009, 18:45 -
DVD Cutter
By akakiami in forum EditingReplies: 6Last Post: 23rd Oct 2008, 07:04 -
Looking for Mpeg2 Cutter
By 557953 in forum EditingReplies: 6Last Post: 8th Sep 2008, 22:56
