How do I copy a dvd that was backed up with dvd x copy?
i did a search but could not pull up anything specific on this topic.
I basically want to make another backup of my dvd, I'm really paranoid ok.
well the easiest way is to use DVD2DVDR, but you will loose the extras and the menus, but you will keep subs, all audio and chapter stops.
Correct me if I am wrong but the Backups made by DVDxCOPY are not protected against using Nero. It seems to me that I was able to copy all of the files off of a DVDxCOPY backup, onto my C:\ drive. Then just use Nero to Burn Again.
Just as cram said, I can confirm: copy protected DVD-5s copied on DVD-Rs with DVDXCOPY can then be copied on-the-fly by Nero, that's all I can say by now!
Bruno, 30
Brussels, Belgium -
this is great news then. So if I copy a single layer 4.7gb movie and can then load the copy onto my second dvd rom drive and use nero to copy on the fly to my dvd-r drive with out hassle.
this is great.
all dual layer dvvd-9 movies I ripp to drive and compress to fit on 1 single dvd-r disc.
thanks for the help guys
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 08:36 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 08:26 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 01:31 -
Extent of copy protection...and ability to tell is a DVD has been copied
By SM9 in forum Newbie / General discussionsReplies: 29Last Post: 26th Jul 2008, 06:16 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 12:23
