I got Iron Maiden Rock in Rio Show.. 2 Avi files with AC3 5.1 channels and when i try to convert the audio to simple wav or mp3 the sound volume is so low.... how could i fix that?? I had to convert the audio because TMPGEnc gave me some PCM initialization error..
Once you're in WAV any decent wav editor should allow you to boost the level.
But seems to me that i lost 3 channels making that kind of convert.. what you think?
i guess the first question is - why even convert it ?
but if you need to - use besweet which will downmix the 6 channels to 2 channel - then if need be , adjust volume (can't remember if besweet might be able to do that also - other wise just use a editor)
Problems importing ac3 in Vegas Pro
By mltwitz in forum AudioReplies: 0Last Post: 12th Jun 2010, 12:55 -
dts to ac3 problems
By scarlac in forum AudioReplies: 5Last Post: 23rd Apr 2010, 02:41 -
Windows 7 AC3 Problems
By eon_designs in forum Video ConversionReplies: 3Last Post: 20th Apr 2010, 04:07 -
Ac3 Downsampling problems
By robbynaish in forum AudioReplies: 1Last Post: 27th Jan 2010, 17:33 -
Problems encoding from Vegas to Divx and AC3
By grendizer in forum Video ConversionReplies: 0Last Post: 6th May 2008, 04:30
