am I supposed to put all the settings the same as with a DivX or just open the AVI and save as wav, cause if i change the settings it dosent work, but if i dont do anything it makes the .wav
thx in advance
does it come up with any warnings when you first load you avi into VDub? If it doesnt then check the video streams for errors. Then click on audio settings, check the compression is pcm, click on avi and go to file menu and save as wave, typing name of file in.
This should save out the uncompressed wave. Use the avi file as your source file in tmpgenc and choose this new wave file as your audio source for tmpenc.
If it comes up with warnings you probably have VBR mp3 as sound.
Hope this helps, there are plenty of posts on this subject so mine is not definitive!
Good luck Tom
Working with Virtual Dub filters
By ryangarfield in forum Capturing and VCRReplies: 4Last Post: 21st Dec 2010, 12:11 -
Working with Subtitles on a 64-Bit System: XVid, SUPER, & Virtual Dub
By jdanniel in forum SubtitleReplies: 17Last Post: 22nd May 2010, 13:08 -
virtual dub xvid codec encoding w/o profile
By caner12 in forum EditingReplies: 7Last Post: 5th Jul 2009, 12:08 -
xvid encoding in Virtual Dub, stats file?
By Xavier in forum Video ConversionReplies: 4Last Post: 10th Feb 2009, 08:46 -
how to set max bitrate(xvid virtual dub)
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 16th Feb 2008, 08:54
