Is there any difference between letterbox and 16:9 movies? Also, some time I see movies classified as 4:3 by DVD2AVI and TMPGEnc but then they appear to me like 16:9
I am totally lost with this ratios issue. Any clarification is appreciated.
In once occasion I had done a DVD that was playing ok at the ratio of 16:9 from the file before burning the DVD. However, once I dunned the DVD it was playing squashed than the original.....why is that?
Any help will help.
Actually, 16:9 is an aspect ratio - letterbox is a way of presenting a 16:9 aspect ratio video on a 4:3 (normal TV) display.
If you have a 16:9 (widescreen) display, a 16:9 movie is not "letterboxed".
Movies with a 16:9 aspect ratio are sometimes encoded on DVDs as letterboxed for a 4:3 display or as "anamorphic" for either 4:3 or 16:9 (the DVD player is typically told which kind of display it is, and it displays the anamorphic video letterboxed on 4:3 or fullscreen on 16:9 displays. -
well, you know what i meant. on a 4:3 tv letterbox is the way to display a 16:9 movie in its correct aspect ratio.
From 4:3 letterbox to 16:9
By Crueltylizer in forum Newbie / General discussionsReplies: 3Last Post: 26th Sep 2010, 10:40 -
Another 4/3 letterbox to 16/9 WS question
By julitomg in forum EditingReplies: 7Last Post: 4th Dec 2009, 16:21 -
getting rid of the letterbox
By jagsman in forum Video ConversionReplies: 4Last Post: 16th Oct 2009, 17:03 -
Converting 16:9 to 4:3 letterbox
By brianschmutz in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 04:15 -
letterbox to 16:9
By marksk918 in forum Authoring (DVD)Replies: 9Last Post: 30th Aug 2008, 02:33
