I'm relatively new to conversion, but i seem to be having one consistent problem - any time i start the dvd to divx (or xvid) conversion, the final product is riddled with compression artifacts. i've tried changing several things, all to no avail.
i'm raised the bitrate -- this helps but ONLY if i raise it to a ridiculous amount like 4000 Kb/s. that would create a huge file.
deinterlace - several different virtualdub options -- smart deinterlace, deinterlace, deinterlace/smooth (this was a minor help, though it took 8 hours for half a movie), field bob, etc. doesn't help. it does get rid of jagged lines, but nothing else
the same happens on xvid or divx. i've tried this mostly in virtualdub, but also in vidomi and flaskmpeg, each with similar results. i've also looked at countless guides and nothing.
what am i missing? any help or a pointing in the right direction would be appreciated. thanks...
alright, somebody's gotta have an idea. anyone?
and if i could have posted this in a more appropriate forum, please feel free to let me know. thanks a lot...
well, when you convert to divx you ARE compressing it. so it should have compression artifacts.
yes, i'm aware that i'm compressing it. i know that divx is a compressed file. nonetheless, the picture shouldn't have as much digital noise as it does.
maybe i'll give Gordian Knot a try. people seem to have some luck with that set up. -
Gordian Knot might not be the most user friendly program, but it is THE tool to make good looking DivX rips (as long as you know what you're doing, of course).
yeah, i'm pretty sure i know what i'm doing.
i've actually made rips for about a year or so now, it's just lately that it's been troublesome.
i used Gordian Knot and it is kind of long-winded but it does work. the artifacts are STILL there, so i'm thinking, that might just be the best possible job that can be done for this particular file. i know i'm not imagining all this, but i've seen better looking divx files.
but oh well -- i now have a better tool to do it with.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 09:11 -
Would synch mostly occur on DVD to DivX, or XviD to DivX?
By rocky12 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2008, 01:01 -
Problem with Vob to DivX Coversion Image Size
By Baggins in forum Newbie / General discussionsReplies: 7Last Post: 8th Oct 2008, 13:50 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25
