Tried 3 times with dvd2avi on Titanic dvd and when trying to import the finished .ac3 into DVD Maestro I keep getting an inconsistent bit rates error .. what do i do to fix this ?
Do you still have the dvd?
If so than use DVDDecrypter to demux the AC3 track.
If you don't have the dvd anylonger you could try using AC3 Delay corrector, or AC3Machine. -
thanks for the tip .. no i dont have the dvd anymore .. hrm .. right now remuxxing with ifoedits dvd authoring will see how well that fares
Hi
You have to run AC3FIX.EXE on your AC3-File, because Maestro found some Frames with the wrong size. -
Thanks for the tips !
BTW -- Ifoedit had no trouble authoring the troublesome .ac3 file .. i think i am dropping maestro off my list and just going to use ifoedit .. i dont do menu's anyway ..
Bit Rates etc....
By Deadmoney in forum Newbie / General discussionsReplies: 7Last Post: 6th Oct 2011, 22:30 -
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 09:40 -
Adobe Media Encoder h.264 at low bit rates.
By x2x3x2 in forum EditingReplies: 5Last Post: 21st Jul 2010, 18:00 -
Target Bit Rates for HD
By Bman. in forum EditingReplies: 2Last Post: 2nd Oct 2009, 11:01 -
optimal bit rates/codec/frame size for HDV on the web
By lafsunlmtd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 15th Aug 2007, 18:09
