  1. Okay here is the deal. I use dvd decrypter and ifoedit. I make perfect copies with decrypter with single layers. Alright, with double layer I do everything perfect and test no problem. However when I try to burn it plays in computer but not stand alone. I know my stand alone plays them because it plays the single layers I make. This means that if I test before burn and it works, the problem lies within my burning technique. I only have roxio and pinnacle on my computer. Roxio will only allow for a dvd data burn. I choose this and copy the folder with the contents to the recordable dvd. Should this work? Should there not be a folder and I just copy the contents? Does the option not work for dvd's at all? This is my problem. If anyone can tell me how to use roxio to burn dvds that play in stand alone that would be great. If not then what should be used to burn, and can I download it for free? I know most people use nero, but have seen many people complaining of problems with it. Does the downloadable demo work for dvd burn in stand alone? If so could I be guided through the burn process or get a link? I appreciate all that take the time to read this and reply. I love this forum, and without all of the posts in here I would have been lost to begin with....
  2. I use Nero 5.5.9.0 and select the following
    DVD-ROM (UDF/ISO)
    Under Multisession tab ...
    No Multisession
    ISO tab...
    ISO Level 2 (Max. of 31 characters)
    Character Set = ISO 9660
    uncheck all other options under ISO
    UDF tab...
    Physical partition
    UDF 1.02
    You should be able to download a demo of nero. I would recomend using RW media to avoid creating coasters.
    -Caleb
  3. Still no luck... plays in computer, but not in my apex or sony. This is starting to suck. I know I am doing everything perfect, but the burn process. Using the nero demo... could somebody guide me through the steps to burning the files onto the dvd. All the tutorials, etc. go into detail until the burn process, and then the just go and say NOW BURN using nero. I try to burn, but get no luck in stand alone. If the one layers I burn using just dvd decryptor work, this should play the dual layers I try to make. They test fine... Very odd, please help. This is driving me crazy to have it all down but this stupid last step.
