Forgive me if this is covered in another post or in a tutorial. If so, please point me in the right direction...
I made my first "successful" burn of an avi file to VCD using Nero 5.5.9.0
The problem is that it made what was a letterboxed version a full screen when I burned it. I used AviSplitCalc to split the file into 2 smaller ones and then used Nero to make 2 VCDs. It would seem that the problem was in Nero's "conversion" of the avi files to the proper format to make the VCD. The finished product plays on my DVD player full-screen. It doesn't appear that it has "stretched" the movie any.
I would like to know if there's a way to keep the letterboxed format when making a VCD. Do I need to use a different program to convert the avi file first, or is there a setting in Nero that needs to be altered?
Here's the details on the avi file I tried to burn (in case it helps):
Size is 576x304
Frame Rate 23FPS
Video sample rate 24 bit
DivX encoded
If anyone can offer any suggestions, please let me know.
Dont use Nero, Use TMPGEnc
http://www.vcdhelp.com/forum/userguides/135238.php
See my sig for other help -
OK, I got TMPGenc, but it seems to be making it fullscreen as well. What setting am I looking for that I need to change to keep the original letterbox format of the avi file I'm working with?
Settings
Advanced
Video arrange method
Full screen (keep aspect ratio) -
in tmpgenc under settings->advanced select 1:1 source aspect ratio and full screen keep aspect ratio under video arrange method
and it should be letterboxed if the source is that. Before you encode hit preview to see how it looks like. -
D'oh! That did it!
Thank you all for your quick responses to help a "noob"
Much appreciated!
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 20:50 -
Anyone with a converter being "denied" letterboxed output?
By vatkat234 in forum DVB / IPTVReplies: 0Last Post: 10th Jul 2009, 11:49 -
Help converting a "HDTV" non-DRM WMV to a PS3 friendly format
By FulciLives in forum Video ConversionReplies: 6Last Post: 17th Sep 2008, 21:39
