hey all. I have a small problem, hope you guys can help me out.
I downloaded a MPEG2 file for an SVCD movie. It plays perfectly fine with PowerDVD on my computer. However when I try to burn it to a CD with Nero, the audio and video sync are out of whack. The video playing rate seems a little faster than the audio. By half way through the movie, the audio is about 5 minutes behind. Anyway, before burning the file to the CD, Nero says that the MPEG2 file is not SVCD compliant, and it attempts to encode it with Nero's SVCD plug-in. After the encoding, the audio and video are out of sync. Any suggestions? Thanks in advance.
Use TMPGenc, load the MPEG file and go to 'Source' under the 'Advanced' tab. Use the 'Audio Gap' box to correct the A/V.
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Nero 7 audio sync problems
By CRJ705driver in forum Authoring (DVD)Replies: 5Last Post: 26th Sep 2010, 02:25 -
audio video avi file out of sync when converting with nero
By paulthewall37 in forum AudioReplies: 2Last Post: 28th Feb 2010, 18:06 -
I moderately dislike Nero Vision (audio sync)
By Matth3w in forum Newbie / General discussionsReplies: 4Last Post: 23rd Nov 2007, 19:53
