background:
I use win2000 on a 750Mhz pentium.
My setup consists of two harddisks (both are 5400),
one formatted with a FAT32 filesystem, the other with NTSF.
All programms, such as videoplayers, are installed to the
system-partition (C) on the FAT32 drive.
My video data is mostly stored on the other drive with NTFS.
problem:
When I play files that are stored on that drive
with NTFS it doesn't work properly.
I get dropouts and poor playing performance
regardless of which player or filetype I use.
[When I play files that are on FAT32 and the same
physical drive as the system everything works well.]
Is the problem related to those different filesystems
or is it of a different cause?
Has anyone found out anything helpful?
thanx.
Results 1 to 9 of 9
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX -
I agree with Greg12 to make it all NTFS, but your problem lies elsewhere. What is the "defrag status" of your NTFS drive? If it is too fragmented, you may experience problems like this. And this will be amplified by your slow system.
NTFS CAN be a good thing, but the only solution? not.
NTFS is as fast as FAT32 at best. (I know someone will say it's faster...) When it gets fragmented and the MFT also becomes fragmented, it's really slow.
Disks have to be defragged, especially NTFS ones -
Originally Posted by SLK001
And it's not the general slowness of the system:
performance on the FAT32-drive is absolutely ok.
However, I'll change FAT32 to NTFS.
How's that being done? which tool? (e.g. partition magic?)
danger of loosing files?XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
make sure dma is turned on for that drive. Or rather both drive for that matter
Now I've changed FAT32 to NTFS.
But the problem remains...
it's something different...?!!XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Doh. Either you didn't read my post, or you ignored it. Convert it all back to fat32 and see for yourself.
finally, it's seems to be ok now.
(after 3 hours of problem analysis)
some setting in the boot options for the NTFS drive
wasn't right so it couldn't be adressed properly.
Apparently it had nothing to do with the filesystem.
Sorry for that misinterpretation.
Thanx a lot for your help anyway.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Best software to re-format NTFS 2TB HDD to FAT32?
By jbitakis in forum ComputerReplies: 26Last Post: 29th Dec 2012, 16:59 -
Converting External HD's from NTFS to Fat32
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 10Last Post: 30th Oct 2010, 13:04 -
External HDD: FAT32 vs NTFS?
By videobread in forum ComputerReplies: 12Last Post: 28th Jul 2008, 16:09 -
For backup, NTFS or FAT32?
By coody in forum DVD RippingReplies: 16Last Post: 1st Oct 2007, 09:30 -
HDD problem NTFS vs FAT32
By edsmith77 in forum ComputerReplies: 4Last Post: 21st May 2007, 11:17
