When capturing audio with ATI TV program, I am getting audio that is clean, but VERY loud. I tried adjusting with the Audio Properties>recording>tv and line sliders, but it is still too loud....any ideas?
thanx
Basically the audio input on a PC soundcard is too sensitive for direct connection to most hi-fi devices, videos or sat receivers. You will need to attenuate the audio by maybe 20dB to get a clean undistorted feed for your PC. The easiest way is to feed the audio through a mixer first. This is what I had to do with my ATI card.
Now I capture using a DV camcoder and realise just how crap the ATI AIW card actually is ... even the TV picture was dreadfull!! -
If your card uses an external loopback cable to feed the tv card audio into the sound card line-in, you can put an inline volume control in the audio feed to attenuate the signal.
Something like this:
RadioShack Part# 42-2559 -
You can use virtualdub to lower the volume of the audio. I thinnk it is done in "X" percentages....
Loud buzz when outputting audio only
By joelkranz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Mar 2014, 23:12 -
Captured audio is REALLY LOUD
By justin81 in forum Capturing and VCRReplies: 4Last Post: 11th Aug 2009, 08:43 -
TV Capture not loud enough
By programm in forum Capturing and VCRReplies: 11Last Post: 10th Mar 2009, 08:48 -
GUI for dvdauthor - audio too loud
By mrcoolekin in forum Authoring (DVD)Replies: 6Last Post: 15th Oct 2008, 05:25 -
Loud Static/Audio Clipping at end of Capture
By brandtb in forum Capturing and VCRReplies: 0Last Post: 2nd Aug 2007, 22:20
thanx
