  1. Anyone here have any comments on the Vitec DCM dvd kit.
  2. Anonymous
    Guest
    I have it. What are you interested in? Better write to me personally.
    Feb 2001
    Macondo, Puerto Rico
    DCM offers extra features not found in the Navis Pro such as:
    1. Fully flexible encoding rate , from 3Mbps to 12Mpbs, CBR and VBR (Navis rpo allows you to encode at 4,6,8Mbps only)
    2. VBR can be your assignment on average, minimum and max. (You cannot set VBR parameters for Navis Pro)
    3. Record audio in formats of MPEG, PCM and AC3 from 224 to 386 Mbps. (Navis Pro records audio at MPEG, 386Mbps only)
    4. Runs on Windows 98, 2000, XP (Navis runs on Windows 98,2000)
    5. Encodes to separate streams or combined streams. (Navis encodes as .mpg combined stream)
    5. Navis comes with NTSC tuner, NOT for DCM.
    Feb 2001
    Hi BennySP,
    I just bought a DCM!
    I will let you know about the performance as soon as I test it!
    Regards,
    Jose
    Feb 2001
    I got the Vitec DCM and this card is awesome!
    After only 5 minutes after signing the UPS papers I was capturing in MPEG2! Extremely straight forward. Excelent instructions. This card does only one thing and does it perfectly. It came with a lot of cables!
    It has real tume contrast/brightness/saturation settings. It even has a blanking option to eliminate the bottom lines from a VHS.
    I bought it yesterday from BernClare (Canada) and got it (Puerto Rico) for only $25. The people at BernClare are excellent.
    Feb 2001
    Hi,
    I am having problem playing the captured mpeg file in my DVD players..It has a lot of mpeg artifacts... I was able to get a viewable dvd by decrease the GOP size to 4 during the capture-convertion process.
    Regards,
    Jose Febus
