  1. I think I may have originally posted this to the wrong fourm, sorry for the double post - hopefully someone here can help with this.
    Just picked up the Pioneer DVR-105, not tried to burn a DVD as yet but having major problems trying to burn some bin/cue and img files. I keep getting a "failed to send cue sheet" or "cue sheet rejected" or similar depending on the program I try (Details below). I have a new P4 2.5/768 with 2x120GB drives running XP Pro SP1 so there is lots of clean disk space. ASPI 4.6 installed and working properly.
    I'm using Nero 5.5.10, tried CDRWIN and Alcohol 120, fireburner, blindwrite...pretty well everthing else as well. I can burn some bin/cue files but not others. I came across a posting (that I can't find) where the guy was describing much the same problem and said it had something to do with extended cue files. Not sure what this means but I have attached one of the cue files that has been causing me grief.
    I can burn these fine on my old 98se machine with either a Sony and Matushita 8x CD burner but the damn 105 is spittingthem back at me. At this point I don't know if it's XP, the burner or some other setting that I am missing.
    Anyone else having this problem? Anyone have any idea what it could be?
    TIA for any help you can offer.
    Rileyman
    Here's some detail - sorry for the wack of info but this is driving me crazy - two years coaster free and now my coaster stack is the same size as my blank stack...please help !!!
    Here's one of the cue files - and yes it's in the same folder as the bin
    FILE "whatever.bin" BINARY
    TRACK 01 MODE2/2352
    FLAGS DCP
    INDEX 01 00:00:00
    TRACK 02 MODE2/2352
    FLAGS DCP
    INDEX 00 00:04:00
    INDEX 01 00:06:00
    INDEX 02 00:06:01
    INDEX 03 19:47:10
    INDEX 04 44:31:73
    INDEX 05 68:27:28
    Here's the error log from Nero
    Windows XP 5.1
    IA32
    WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 9/10/1999 12:06:00 PM
    ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.50, size=131072 bytes, created 6/25/2002 4:34:54 PM
    Nero Version: 5.5.10.0
    Recorder: <PIONEER DVD-RW DVR-105> Version: 1.21 - HA 1 TA 0 - 5.5.10.0
    Adapter driver: <atapi> HA 1
    Drive buffer : 2000kB
    Bus Type : default (0) -> ATAPI, detected: ATAPI
    CD-ROM: <PIONEER DVD-RW DVR-105>Version: 1.21 - HA 1 TA 0 - 5.5.10.0
    === Scsi-Device-Map ===
    DiskPeripheral : Maxtor 6Y120L0 atapi Port 0 ID 0 DMA: On
    DiskPeripheral : Maxtor 6Y120L0 atapi Port 0 ID 1 DMA: On
    CdRomPeripheral : PIONEER DVD-RW DVR-105 atapi Port 1 ID 0 DMA: On
    CdRomPeripheral : AXV CD/DVD-ROM 2.1a vdevax Port 2 ID 0 DMA: ?
    AutoRun : 1
    Excluded drive IDs:
    CmdQueuing : 1
    CmdNotification: 2
    WriteBufferSize: 83886080 (0) Byte
    ShowDrvBufStat : 0
    EraseSpeed : 0
    BUFE : 0
    Physical memory : 767MB (785888kB)
    Free physical memory: 524MB (536640kB)
    Memory in use : 31 %
    Uncached PFiles: 0x0
    Use Static Write Speed Table: 0
    Use Inquiry : 1
    Global Bus Type: default (0)
    Check supported media : Enabled (1)
    Wizard: Off
    5.1.2003
    CueSheet
    10:03:44 PM #1 Phase 90 File dlgbrnst.cpp, Line 1649
    Buffer Underrun Protection activated
    10:03:44 PM #2 Text 0 File Reader.cpp, Line 115
    Reader running
    10:03:44 PM #3 Text 0 File Burncd.cpp, Line 3790
    Turn on Disc-At-Once, using CD-R/RW media
    10:03:44 PM #4 Text 0 File ThreadedTransferInterface.cpp, Line 659
    Setup items (original item values)
    0: TRM_DATA_RAW_MODE2 (Cue Sheet Track)
    2 indices, index0 (150) provided
    original CD pos #0 + 300 (300) = #300/0:4.0
    relocatable, CD pos for caching/writing not required/not required, no patch infos
    1: TRM_DATA_RAW_MODE2 (Cue Sheet Track)
    6 indices, index0 (150) provided
    original CD pos #0 + 1 + 88584 + 111363 + 107655 + 50189 (357792) = #357792/79:30.42
    10:03:48 PM #5 Text 0 File DlgWaitCD.cpp, Line 202
    Last possible write address on media: 359848 (79:59.73)
    Last address to be written: 358241 (79:38.41)
    10:03:48 PM #6 Text 0 File DlgWaitCD.cpp, Line 207
    Write in overburning mode: FALSE
    10:03:48 PM #7 Text 0 File DlgWaitCD.cpp, Line 1419
    Recorder: PIONEER DVD-RW DVR-105;
    CDR code: 00 97 24 01; OSJ entry from: Taiyo Yuden Company Limited
    ATIP Data:
    Special Info [hex] 1: 00 00 00, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00)
    Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
    10:03:48 PM #8 Text 0 File ThreadedTransferInterface.cpp, Line 811
    Prepare recorder PIONEER DVD-RW DVR-105 for write in cue-sheet-DAO
    DAO infos:
    MCN:
    TOCTYPE: 0x20 Session Closed, CD fixated
    Tracks 1 to 2:
    TRM_DATA_MODE2_2336, 2336/0x0, ISRC "", FilePos 0 350400 1051200
    TRM_DATA_MODE2_2336, 2336/0x0, ISRC "", FilePos 1051200 1401600 837203712
    10:03:48 PM #9 Text 0 File ThreadedTransferInterface.cpp, Line 659
    Setup items (after recorder preparation)
    -> TRM_DATA_MODE2_2336, 2336, config 0, wanted index0 0 blocks, length 300 blocks [PIONEER DVD-RW DVR-105 ]
    -> TRM_DATA_MODE2_2336, 2336, config 0, wanted index0 0 blocks, length 357792 blocks [PIONEER DVD-RW DVR-105 ]
    10:03:48 PM #10 Phase 36 File dlgbrnst.cpp, Line 1649
    Burn process started at 16x (2,400 KB/s)
    10:03:48 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 1952
    Verifying CD position of item 0 (relocatable, no CD pos, no patch infos, orig at #0): write at #0
    10:03:48 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 1952
    Verifying CD position of item 1 (relocatable, no CD pos, no patch infos, orig at #0): write at #450
    10:03:48 PM #13 Text 0 File Mmc.cpp, Line 12522
    StartDAO : CD-Text - Off
    10:03:48 PM #14 Text 0 File Mmc.cpp, Line 17129
    Set BUFE: supported -> ON
    10:03:48 PM #15 SCSI -1067 File Cdrdrv.cpp, Line 1189
    SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0231E000
    Status: 0x04 (0x01, SCSI_ERR)
    HA-Status 0x00 (0x00, OK)
    TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
    Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
    Sense Code: 0x26
    Sense Qual: 0x00
    CDB Data: 0x5D 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x50 0x00 0x00 0x00
    Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0E
    0x00 0x00 0x00 0x00 0x26 0x00
    10:03:48 PM #16 Text 0 File Mmc.cpp, Line 12780
    CueData, Len=80
    41 00 00 24 00 00 00 00
    41 01 00 20 00 00 00 00
    41 01 01 20 00 00 02 00
    41 02 00 20 00 00 06 00
    41 02 01 20 00 00 08 00
    41 02 02 20 00 00 08 01
    41 02 03 20 00 13 31 0a
    41 02 04 20 00 2c 21 49
    41 02 05 20 00 44 1d 1c
    41 aa 01 24 00 4f 26 2a
    10:03:48 PM #17 DVDR -1067 File ThreadedTransferInterface.cpp, Line 1397
    Invalid field in parameter
    10:03:48 PM #18 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1397
    Could not perform start of Disc-At-Once
    10:03:48 PM #19 Phase 38 File dlgbrnst.cpp, Line 1649
    Burn process failed at 16x (2,400 KB/s)
    10:03:48 PM #20 Text 0 File Scsicmd.cpp, Line 406
    SCSI not using temporary buffers
    20 out of 20 temporary buffers allocated
    Existing drivers:
    File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 9/10/1999 12:06:00 PM
    File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 8/29/2002 1:27:50 AM (Adapter driver for rec)
    Registry Keys:
    HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
    Here's a sample CCD that I'm having trouble with
    [CloneCD]
    Version=3
    [Disc]
    TocEntries=4
    Sessions=1
    DataTracksScrambled=0
    CDTextLength=0
    [Session 1]
    PreGapMode=1
    PreGapSubC=0
    [Entry 0]
    Session=1
    Point=0xa0
    ADR=0x01
    Control=0x06
    TrackNo=0
    AMin=0
    ASec=0
    AFrame=0
    ALBA=-150
    Zero=0
    PMin=1
    PSec=0
    PFrame=0
    PLBA=4350
    [Entry 1]
    Session=1
    Point=0xa1
    ADR=0x01
    Control=0x06
    TrackNo=0
    AMin=0
    ASec=0
    AFrame=0
    ALBA=-150
    Zero=0
    PMin=1
    PSec=0
    PFrame=0
    PLBA=4350
    [Entry 2]
    Session=1
    Point=0xa2
    ADR=0x01
    Control=0x06
    TrackNo=0
    AMin=0
    ASec=0
    AFrame=0
    ALBA=-150
    Zero=0
    PMin=70
    PSec=37
    PFrame=6
    PLBA=317631
    [Entry 3]
    Session=1
    Point=0x01
    ADR=0x01
    Control=0x04
    TrackNo=0
    AMin=0
    ASec=0
    AFrame=0
    ALBA=-150
    Zero=0
    PMin=0
    PSec=2
    PFrame=0
    PLBA=0
    [TRACK 1]
    MODE=1
    INDEX 0=-150
    INDEX 1=0
    And here's the Log from Alcohol 120% when trying to burn the ccd above
    ===---------------------=== System Information ===---------------------===
    Windows XP Professional 5.1 Service Pack 1 (Build 2600)
    Processer info : Intel(R) Pentium(R) 4 CPU 2.53GHz (2538MHz)
    Memory Available to Windows: 785,888 KB
    Devices control interface : Default Driver Control Interface
    ===-------------------=== Alcohol 120% Information ===--------------------===
    File Name : C:\Program Files\Alcohol Soft\Alcohol 120\Alcohol.exe
    Company Name : Alcohol Soft Co., Ltd.
    Description : Alcohol 120%
    Original : alcohol.exe
    Product : Alcohol 120%
    Trademarks : Alcohol Soft Co., Ltd.
    Copyright : Copyright (C) 2002 Alcohol Soft Co., Ltd.
    Version : 1.3.5 ( Build 1112 )
    Date : 2002/11/13
    File Name : C:\Program Files\Alcohol Soft\Alcohol 120\alcoholx.dll
    Description : Alcohol virtual device control library
    Original : alcoholx.dll
    Product :
    Trademarks :
    Copyright : Copyright (C) Alcohol Soft Co., Ltd. 2002
    Version : 3.26.0 ( Build 0 )
    Date : 2002/11/11
    File Name : C:\Program Files\Alcohol Soft\Alcohol 120\devsupp.dll
    Description : Alcohol Software Device Capabilit Library
    Original : devsupp.dll
    Product : Alcohol Software Device Capabilit Library
    Trademarks :
    Version : 2.2.1 ( Build 1112 )
    Date : 2002/11/13
    ===--------------------=== User Information ===----------------------===
    User Name : vvvvv
    Company Name : vvvvv
    Registered User ID : vvvv
    ===-------------------=== Devices Information ===--------------------===
    (D PIONEER DVD-RW DVR-105 (1:0)
    (G AXV CD/DVD-ROM (2:0)
    ===---------------=== Devices Detail Information ===-----------------===
    Note: This information is provided by the unit, it might be inaccurate.
    This software does not use this information!
    Report (D PIONEER DVD-RW DVR-105 (1:0) Detail Information.
    Vendor ID : PIONEER
    Product ID : DVD-RW DVR-105
    Firmware Version : 1.21
    Host/Target ID : 1/0
    Removable media: YES
    ANSI Version : ATAPI SFF8090
    Respone Data Format : 02H
    CD-R Read/Write : YES/YES
    CD-RW Read/Write : YES/YES
    Read CD-R fixed Packet : YES
    Test Write : YES
    DVD-ROM Read : YES
    DVD-R Read/Write : YES/YES
    DVD-RAM Read/Write : NO/NO
    Audio Play : YES
    Composite Audio and Video Data Stream : NO
    Digital output(IEC958) on port 1 Supported : NO
    Digital output(IEC958) on port 2 Supported : NO
    Mode 1 Form 2 : YES
    Mode 2 Form 2 : YES
    Multi-Session : YES
    BUF : YES
    CD-DA Commands supported : YES
    CD-DA Stream is Accurate : YES
    R-W Supported : NO
    R-W De-interleaved & Corrected : NO
    C2 Pointers Support : NO
    ISRC Supported : YES
    UPC Supported : YES
    Read Bar Code : NO
    Lock media into the drive : YES
    Currently drive Lock state : Unlocked
    PreventJumper : NO
    Eject Command : YES
    Separate volume leavels : YES
    Separate channel mute : YES
    Changer Supports Disc Present : NO
    Software slot selection : NO
    Side change capable : NO
    P through W in Lead-In : YES
    ===------------=== Source Disc/Image Information ===----------------===
    Type : CloneCD Image file
    Path : C:\Program Files\nbpro\DOWNLOAD\alt.binaries.cd.image\cw.sxl2
    cw.sxl2.img
    cw.sxl2.sub
    Session: 1
    Track: 1
    Session 01 :
    Track 01 : Mode 1, Length : 317631(620.4 MB), Address : 000000
    ===------------=== Recording Progress Detail Log ===----------------===
    PM 08:31:05 Processer info : Intel(R) Pentium(R) 4 CPU 2.53GHz (2538MHz)
    PM 08:31:05 Memory Buffer using size: 128 MB
    PM 08:31:06 Image file loading : C:\Program Files\nbpro\DOWNLOAD\alt.binaries.cd.image\cw.sxl2 \cw.sxl2.ccd
    PM 08:31:06 Source Info : Session : 1, Track : 1, Length : 620.4 MB / 070:35:06
    PM 08:31:06 (D PIONEER DVD-RW DVR-105 (1:0) : Recording Method/Speed
    PM 08:31:06 Recording - DAO / SAO - 16X (2400 KB/Sec)
    PM 08:31:06 (D PIONEER DVD-RW DVR-105 (1:0) : BURN-Free activated
    PM 08:31:06 (D PIONEER DVD-RW DVR-105 (1:0) : [SEND CUE SHEET ERROR]
    CDB : 5D 00 00 00 00 00 00 00 20 00 00 00
    D:-0--1--2--3--4--5--6--7--8--9--A--B--C--D--E--F--
    41 00 00 14 00 00 00 00 41 01 00 10 00 00 00 00
    41 01 01 10 00 00 02 00 41 AA 01 14 00 46 25 06
    S:KEY - 05/26/00 - "Invalid Field In Parameter List"
    PM 08:31:06 (D PIONEER DVD-RW DVR-105 (1:0) : Recording failed!
    PM 08:31:06 Error message : [05/26/00] - Invalid Field In Parameter List
    PM 08:31:06 Image file loading aborted!
    PM 08:31:08 Something is wrong with the recording procedure!
    Please check the log file and report any errors to Technical Support.
  2. I'm not too sure if this will fix your problem, but you can remove the subindices in the cue sheet by using the "Subindicies Remover" function in GNU VCDImager Tools GUI: http://www.michaeltam.com/vcdimager_tools_gui.html
    Best of luck.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  3. hey ok well i had a similar problem with using cdrwin but thats fixed but now when i go to "record disk" mind u im trying to brun a cue file now this error comes up...
    Error: 'WRITE' command failed on device 1:1:0
    Illegal command request (04h 00h 02h 05h 10h 02h)
    so now im stuck! some help would be greatly appreciated!!
