can people share how they installed dvd2dvdr because my installation is not working correctly. i have windows xp, an aspi driver, cce 2.5 sp, dvd2avi, and ifoedit. thanks a lot
True Story
I've got the same problem. I read somewhere that you need to install Windows SP3 to dl DVD2DVDR. Before, I couldn't even begin the dl.. after installing SP3, I can dl it but just before completion, it give me some sort of error code in German, saying.. ??? I don't know what..
Anyone? -
All you need to do is run setup.exe then click ok and then click on the computer icon in the top left corner. if it asks you any more questions in german just click the left button.
Thank you. So you're saying once I get to my pc, search for 'DVD2DVDR setup.exe' file, open/run it.. click the left button all the way thru.. at end, click the computer icon at top-left of the program window... correct?
Thanks in advance. -
Download the DVD2DVDR zip file, extract the contents to a directory then you run Setup.exe, then click on ok, Then it will ask where you want to install the program (defaults to c:\program files\dvd2dvdr so just click the computer icon and the install begins.
During the install it may come up with boxes with german text so all you need to do is click the left hand button and it will install correctly.
If you have attempted to install it in another way first you will need to uninstall it first. -
scaronelly
Everyone keeps making the same mistake do not click on any of the buttons that have text instead click on the large ICON that looks like a PC. -
hey guys,
and what can I do if I run DVD2DVD-R when I always see Error-Message
"Typen unvertraglich" in German
Different installation problem
By dmf in forum ffmpegX general discussionReplies: 9Last Post: 11th Jan 2012, 16:02 -
Installation of ffmpegx
By Docdawh? in forum ffmpegX general discussionReplies: 12Last Post: 19th Nov 2010, 01:13 -
ffmpegX installation
By barry3333 in forum ffmpegX general discussionReplies: 38Last Post: 25th Feb 2008, 20:43 -
Which codecs for new XP installation?
By trueman in forum Newbie / General discussionsReplies: 4Last Post: 3rd Feb 2008, 03:34 -
Problem with the installation!
By defacta in forum ffmpegX general discussionReplies: 3Last Post: 20th Jul 2007, 00:37
