Been lookin around for this problem but cannot find one here so if u know could you let me know.
Compatibillity issue(everyone loves these).
Successfully backed up several dvd`s fine all play in ps2,lecson,cyberhome.
However problem in backing up dv5(seen the guides no help)
example: behind enemy lines
Dvd decryptor (whole disc) removing rc/rce
ifoedit (get vts sectors as removing rc/rce alters ifo`s)
burn with nero (create VIDEO_TS/AUDIO_TS) version 5.5.9.17 (udf/iso v1.02)
Plays in ps2/Lecson dv900/cbyerhome 402 BUT WILL NOT PLAY IN LG3200E.
It is detected as dvd disc but then gives bad disc error, pretty sure it is not the media but maybe an authoring issue within ifoedit (ie first play area/title 1)
Could anyone elaborate PLEASE!!!!!!
If tomorrow doesn`t exist where shall we all be the day after tomorrow!!!!!!!!!!!!!!!!!!!!
Instead of ripping all the files with DVDDecrypter use ISO mode.
Read will write an ISO file to your hardrive.
Write will burn a DVD using the ISO file you created.
Hope this helps
Caleb -
I'll try that one cheers for the input.
If tomorrow doesn`t exist where shall we all be the day after tomorrow!!!!!!!!!!!!!!!!!!!! -
Iamcaleb.
You r a star, worked a treat.
Cheers for the tip.If tomorrow doesn`t exist where shall we all be the day after tomorrow!!!!!!!!!!!!!!!!!!!!
