what is the best program for copying a dvd that is 4gig from original i have tryed prassi it just does a error i tryed nero (i use this to copy copys i have backed up) it copyd but not good bicture is blockey any 1 got any i deas should i rip the whole disk and try that way ????? please help asap thanks![]()
Results 1 to 21 of 21
Have you tryed , using dvd decrypter to put onto your hardrive.Then
dragging the files into Nero- dvd video, then burn. -
What Kacey said should work for you. I have some guides on my site that will help you. (URL is in my sig).
Cheershttp://encoding.n3.net <-- for all your DVD and CD backup needs! -
1* Create a VIDEO_TS and an AUDIO_TS folder.
2* Open DVD decrypter and in mode set it to files.
3* Select all files and rip them into the VIDEO_TS folder
4* Burning:
NERO: Choose DVD/ISO, UDF 1.02, select the 2 folders and burn.
RecNow: Data disk, select the 2 folders, burn
After that I guess u know what to do.[-Neoh*-]|[-Cheers-] -
All of these things will work, but by far the easist way to do this, is in DVDDecrypter.
Select Mode - ISO - Read
and than once you got the ifo file on your hardrive
Select Mode - ISO - Write
It's that easy! :P -
IamCaleb
Yes it is that easy but what do you do when it says that there is NOT enough space on the disk to do an exact copy?????
Corwin261 -
Corwin261,
When do you get this error? When you are creating the ISO on to the hardrive, or when you are copying the ISO on to a DVD-R? -
ok thanks guys for all the input on guy said use primo dvd but like i said i already tryed prassi lol never mind i am curently burnin with nero after ripping all files wih smartripper and corecting vobs with ifo edit will let u know if it works
robboughton,
All you need to use is DVD Decrypter
Use ISO read to create the ISO file
Use ISO write to burn the disc.
It will automatically disable macrovision and regions. If set up under settings. -
What are you trying to correct with IfoEdit ? If original disk is 4G, just rip and burn. Don't correct VOB's. You can make it region free and remove P-UP's, but don't correct VOB's with "Get VTS sectors"
If DVD Decrypter shows Number of Layers: 1
than all you need to do is rip and burn.
If Number of Layers: 2
You will have to either strip extras or re-encode
(Number of Layers is on the right side of the ISO read screen)
-Caleb -
ok the disk in question is peter kay live at top of the tower it is brand spankin not even a finger print on the disk its hangin at 95% with dvd decrypter will try again now. and if i do a disk to disk copy picture and sound is real bad i tryed ripping the whole disk to hd i came up with errors untill i corected vts sectors but the picture and sound is stil real bad any ideas
Maybe your standalone player have problems with reading your disk. There is no reason to have sound or picture bad other than media compatibility or burning program issue.
OK... Let's try this... Let's collect some info.
What is your burner and what firmware version? You use DVD Decrypter, what version? What burning software do you have and what version? What kind of media and brand do you use ? Is your burner internal or external ? Hmm.... some more questions ??? Let's see what can be done. -
cheers guys 4 all ya help i have sorted the prob now it was a doggy dvdrw as i copyd 1 i already have and same prob lol stupid me
Iamcaleb:
Great method. At first I was tripping because my DVDDecrpyter didn't have those options under mode. I soon discovered that I didn't have the latest version. I got 3.1.4.0 and copied a single layer DVD in no time with zero problems.
I've been a big fan of DXC but this method is very easy and I can easily avoid the 321 studio screens.
graysky:
Your site especially, the "DVD Project" is absolutly AWESOME !!!
best sw to copy an original dvd to another dvd
By marlo in forum Newbie / General discussionsReplies: 9Last Post: 6th Aug 2010, 07:07 -
how to copy an original disc
By marlo in forum Newbie / General discussionsReplies: 6Last Post: 24th Feb 2009, 16:26 -
How Do You Identify Whether The CD You Bought On Ebay Is An Original Copy?
By Nitro89 in forum Off topicReplies: 9Last Post: 22nd Oct 2008, 06:41 -
Can I copy an original DVD to VCD?
By cxgcxg in forum Newbie / General discussionsReplies: 4Last Post: 31st Mar 2008, 05:50 -
How to copy the formatting of the original dvd subtitles
By jujuandhuhu in forum SubtitleReplies: 5Last Post: 12th Mar 2008, 22:33
