i tried ripping a movie that was less than 4.7 gb with smartripper and when it was reading the files, it gave an error that one of the files was still locked. can someone help me, its probably a really easy answer but i cant figure it out..thanks
by the way, i have a memorex dvd+rw/+r
all you need to do is play the dvd for a couple of seconds in a software dvd player to unlock the files, or get an aspi adapter
If you haven't tried this already try playing the DVD with your DVD player's media software (PowerDVD or whatever) before using Smartripper. Smartripper needs it to be played first so it can get the copyprotection algorythm from the player. Then it will be able to rip. If it still doesn't work then I don't know.
Good luck -
try either using clad dvd to put it on your drive then try converting or directly convert it with dvdx because I've had that trouble before and those programs normally work for me
i played the movie (the program, ntsc) in powerdvd for a little while and then reopened smartripper and it said a file is still locked. i followed the rest of the directions and selected all the files and hit start and it took me to a progress window. its been awhile and it hasnt made any progress...is that because it is still locked?
Try installing ASPI and it should work
http://www.doom9.org/Soft21/SupportUtils/forceaspi17.rar
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 14:26
