I have a dvd rom on my computer. I'm not sure of the make and model, but when I looked it up under the device manager, it comes up as Atapi 12X dvd rom. The problem I'm having is that it will play a audio cd with some difficulty but will not play a dvd at all. When I go to My Computer and click on the E. drive(dvd rom drive) it tell me to insert disk when there is a dvd in there already. Any help would be appreciated. I tried cleaning the drive with a cleaner and still no luck.
Is this something that always has happened or did it just start/when ?
Check to make sure DMA is enabled for that channel/drive.
Check the BIOS and see what the settings are at.
Check to make sure the jumpers on the DVD-ROM are correct(Master/Slave)
I hope it is an easy fix, these things can be frustrating. -
It use to work and then I had to reinstall my system , now it doesn't work. Could it be conflict with other software?
I'm still having this problem and could sure use the help. When I tried to reinstall the driver for it , it tells me it has already found one. Its some sort of Microsoft thing. But that's not what I originally installed as the driver. The driver that this Delta 12X DVD ROM came with can not be installed when I go to the Device Manager.HELP!
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 09:33 -
Another DVD Rom issue
By dafoe in forum DVD & Blu-ray WritersReplies: 5Last Post: 16th Jul 2010, 12:49 -
CD \ DVD ROM not seen in Windows
By lacywest in forum ComputerReplies: 1Last Post: 16th Oct 2009, 10:19 -
dvd rom problem
By ieh4f in forum DVD & Blu-ray WritersReplies: 2Last Post: 13th Jun 2008, 03:49 -
dvd rom discs
By johnbud in forum MediaReplies: 3Last Post: 26th Jul 2007, 07:03
