Hi all-
I'm SOOOOOOOOOOOo confused. I downloaded divx and the codecs.....where do i extract these files to?
After extracting, it will work automatically?? Pls advise.
There should be a setup file with it and once you run it it should install it automatically for you. You could also just get the Nimo Codec pack and that would install the codecs you need also. Here is the website for it.
http://www.btinternet.com/~nimosiro/
Hope that helps. -
the full nimo pack is full of spyware - go for the "lite" pack, also your codecs should end up in your system32 folder
Thanks for the tip i did not know that it had spyware in it. Any idea what spyware it installs?? I guess it is time to run adware to get rid of it.
What is divx and xvid codec?
By Azrail in forum Newbie / General discussionsReplies: 4Last Post: 5th Oct 2010, 22:31 -
DivX and xVid codec
By cheerful in forum Software PlayingReplies: 9Last Post: 10th Jan 2010, 22:55 -
Is there a free DivX codec for Dr.DivX?
By Djard in forum Newbie / General discussionsReplies: 1Last Post: 10th Feb 2008, 04:33 -
Different DIVX codec, different output size.
By DonGallego28 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jan 2008, 10:08 -
Best free DIVX codec?
By DonGallego28 in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2007, 19:45
