  1. I'm quite new to DivX encoding - unlike DVD2VCD - and I've searched this forum with no answers to my problem. So here goes:
    A DivX file plays superbly on its own, but encoding it to VCD in TMPGEnc leads to no sound.
    I tried extracting/re-encoding the audio using AVI2WAV
    The DivX sample is 1m8s
    The Re-encoded WAV is 58s
    Why is this?
    This difference is causing TMPGEnc to crash. (Also - of course - there are sync problems)
    The DivX has the following specs:
    audio bitrate 157kbps
    MPEG Layer 3
    Video framerate = 23 fps (I want to make a PAL VCD)
    Encoded with: DIVXMPEG V3
    Dec 2002
    Where did you get the avi? 23 fps is non-standard video rate. 157 kbps is a non-standard audio rate.
    Try one of the guides or any of the 500 posts on 'DivX audio problems with TMPGenc'
    To Be, Or, Not To Be, That, Is The Gazorgan Plan
